cracked screen
elenim
cracked screen
Hi all new to the forum. Any idea how much it would cost to repair my screen?it's only a small crack at the bottom but I am worried that it might spread
2 REPLIES 2
dandy63
Leader
Hi, difficult one i'm afraid.....if its the front screen it really is best to contact your local Xperia Care about it & if they do repair it at least your warranty for any other problems that may arise in your phone are covered, tho i am not sure if your cracked screen will be covered by warranty as a lot of people have found out Slightly_frowning_Face
Both screens can be repaired by a 3rd party repairer but this will void your warranty i'm afraid but be careful to get a guarantee from them incase they damage anything else in doing the repair.
Hope this helps & good luck :smileysmileywink:
Jake-SonyXperia
Champion
Hi elenim,
Welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
Please see the link below to contact Sony Mobile within your region regarding this issue.
http://support.sonymobile.com/global-en/contactUs/
I apologize for the inconvenience.
