Disable USSD messages on xperia e3
Sam8
Hi, I have android kitkat running on my Sony Xperia E3. I use it in India with Airtel as the wireless provider.
The issue is whenever I use any amount of 3g it gives a popup USSD message. I have to press ok many times to remove this annoying message.
Is there any app in google play store that will disable popup of these USSD message and works in Android Kitkat?
Kindly assist! Thanks a lot!
1 REPLY 1
Thommo
USSD means Unstructured Supplementary Service Data - Which in this case is a service message pushed to your device from your network/service provider so you would need to speak to them regarding this and ask for their code to turn off these messages
