Disabling/Enabling option for Reject Call for message
SudeepShakya
When someone calls, there is an option to reject call by sending a message. The problem is that, when someone calls, if my phone is in pocket, due to movement, call reject message is sent(it occurs frequently), this I don't want. How to disable/enable this feature ??
8 REPLIES 8
Uliwooly
You can't disable this option.
SudeepShakya
Any other solution ??
Uliwooly
Add a pin/pattern lock, or if you keep your phone on your pocket, make sure that the screen is facing away from your leg.
SudeepShakya
I have pattern lock but when someone calls, I don't have to unlock the pattern. Is there anyway to apply pattern lock while someone is calling ?
Uliwooly
My bad, no there isn't
SudeepShakya
Is there any other options ??
Uliwooly
There isn't
you can contact your local Xperia Care
http://support.sonymobile.com/global-en/contactUs/
ShinOrochiX
There is no way of disabling the reply with msg feature during an incoming call. What may help is to disable glove mode, the glove mode increases touch sensitivity so the phone is much more likely to register touches without you knowing e.g. when in pocket.
I have experienced similar issues, turning off glove mode helped. :smileysmileywink:
