Does Pokemon Go work on M4?
blue19
Hi, would anyone be able to tell me if Pokemon Go works on a Sony Xperia M4 Aqua?
5 REPLIES 5
profile.country.PH.title
MarlonUk1
https://support.pokemongo.nianticlabs.com/hc/en-us/articles/221958248-Supported-devices
Android
  • Android 4.4 to Android 6.0.1
    (Android N will not supported until the official Android release)
  • Preferred resolution of 720x1280 pixels (Not optimized for tablet)
  • Strong internet connection (Wi-Fi, 3G, or 4G)
  • GPS and Location Services
  • Intel CPUs are not supported
Xperia M4 should be able to run Pokemon GO
Zolfolt
No.
 I just purchased this phone today to play Pokemon Go and it does not work. All of the spec's are capable but the play store says the "device isn't compatible with this version". Also the phone does not have a gyroscope so the AR parts of Pokemon Go would not work even if I could get it to run.
 I will be returning the device tomorrow.
sumitbaran
I am using M4 Aqua Duel and also playing Pokemon Go. No problem.
Screenshot_20160727-000316.pngScreenshot_20160727-000338.pngScreenshot_20160727-000217.png
YoGem
Leader
Blue19 and Zolfolt, the M4 can run Pokémon go and while a gyroscope may be recommended for better user experience a simple accelerometer can do the trick. It may be somewhat shaky at times but it will work for sure. I am pretty sure that you get that message due other limitations (do you have an SD card? Perhaps you got the 8gb versions?)
Jayarajj
It is running smoothly
