Emma Login
Anii
Emma Login
im register today for use emma but i dont receive email for approve,,,, why so hard to create new acount for use emma
1 REPLY 1
Thommo
You don't need to register - Read the instructions as it says to copy a file across to the Program files folder - see point 3
  1. Download the Flash tool for Xperia devices.
  2. Unzip the file you downloaded and place it somewhere on your computer.
  3. In the unzipped folder, run Emma.exe.During the installation, make sure you remember the installation path:
    1. Default path in Windows 64 bit is: “C:\Program Files (x86)\Sony Mobile\Emma\”
    2. Default path in Windows 32 bit is: “C:\Program Files\Sony Mobile\Emma\”
  4. Copy the Customization.ini file. You find it in the Flash_tool_for_Xperia_X.zip.
  5. Paste the Customization.ini file into the installation folder. The installation folder is the folder named Emma in the installation path examples on point 3.1 and 3.2 above.
  6. Click Start > All programs > Sony Mobile > Emma (if you used the default installation path from step 3 above) to start the flash tool
