That sounds strange. As far as I know, it's only possible to enable/disable the use of two SIM-cards via Dual SIM settings. Have you tried to restart the phone? Perhaps you could try to change the SIM-cards (SIM1 to SIM2 slot) just to see if same behaviour persist.
