Hi all
I think we need application end tab (botton) this can be found in all previous sonyericsson models at least that what I saw in my K800, some time I can't end the app. from inside the application cause hanging and vedioDJ is not included in the SATIO and also I can't save image whe zoom in even in the picture editing do those things are important or not.
Well, there is an "end button"! Just press and hold the menue button in the middle (the one with the white point). A small menue will appear with all running applications.
Press and hold the icon for the application you want to end and a small sub-menue will appear giving you the option to terminate the application.
It does not work everytime, but mostly.
Greetings
KimbaDWL
