factory reset
Tasneem11
factory reset
How do i backup all my data before factory reset?
Tags (1)
2 REPLIES 2
Thommo
If it turns on then connect to a pc etc and use Pc Companion or another app of your choice and for contacts I prefer to create a .vcf file by opening contacts then options then Export to internal storage then saving the .vcf file to my Pc
Uliwooly
There are multiple alternatives
http://talk.sonymobile.com/thread/36355
