file manager for experia e c 1505
hettygrew
Hi everyone, can anyone advise me? I mistakingly deleted the file manager app that came with my experia e c1505. subsequently Im having problems also with the sd card. Do I have to download  the specific file manager that i had originally provide by sony, or can i use any file manager? if so Im presuming i will find how to transfer data to the sd card as my phone memory is getting full. Thank you x
4 REPLIES 4
profile.country.RO.title
_alexdon_
You can use any file manager (astro,androzip,file commander etc).
alexdon
Thommo
I prefer to use File manager HD
Jake-SonyXperia
Champion
Hi hettygrew,
Welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
If you want the same app that you deleted this application is called File Commander, this can be directly downloaded from the Play Store and is very simple to use.
It is as easy as Cutting and pasting in to the SD with the File manager to clear space on the internal storage, just make sure you only do this to media content and documents.
I hope this helps.
sanjeevkumar
ES file explorer is the deFacto standard explorer for any android. It is the best fullfeatured explorer that I have ever used.
