Flash Xperia without losing OTA updates
harikni
How to flash downgrade the Version without losing OTA/warrenty. What are the option I need to select(image show below) during Flash ?
2 REPLIES 2
Uliwooly
Thommo
When using Flashtools leave all ticks where they are, Don't change anything and yes OTA updates will still work if your bootloader is still locked and or you haven't rooted, You may root without unlocking your bootloader as seen in say the Z1 but should you then update you will loose root
