when i was falshing my device ... it shows that device connected is not functioning... and when i switched on my phine its shows error symbol and it doesnt starts.... please help!!!!!
Sorry to say this but you have been messing about with your phone for weeks - Rooting and manual flashing, looks like you finally managed to break it - Try EMMA for Sony developers but not sure if it's compatible
please tell how to get through...
i think its not compatible..
EMMA will not work bc the phone is/was locked to a carrier/network branded
Did you downloaded the correct FTF file? how you try with PCC ?
yes!!! i downloaded correct ftf file... can repair my phone will work like in pcc
yes
