How to unlock Xperia T if I have forgotten screen password?
You have 2 options
1. keep trying to remember
or
2. factory reset your phone
if you want to factory reset, you will lose everything
Bridge (for Mac)
Hi Jovanasb,
Welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
If the screen has been locked, then you will not be able to perform a Factory Reset you will need to perform a Software repair on the handset.
Please use the links Uliwooly has provided above to perform this task.
i hope this helps.
