shall i do format reset after update 4.3 ?
It helps in some cases(if you have some problems after update).But it is not necessarily to factory reset.
my proplem my sp lagging and many system apps working at same time ... 700 mp of ram used
so what should i do ?
if fill your phone is slow and a bit lagy do factory reset...i do factory rest also..and no problem exist
Try either a factory reset or repair via sony update service.
hmm ok i did back up for my app data and everything else using Back up & restore app already in phone .... when i do factory reset will i lose my restore ?
No,the backup is made on the google servers.But I suggest backing up with pc companion also.
no i mean i used back up&restore app it's already come with android system and i made restore on sd card .. so when i use format reset will i lose this restore ?
thnx for ur help
You need to restore after the factory reset,not before.
