Front camera doesn't work after dropping the phone
1812
Hi Im Nick from HK! I accidentally dropped my C5 ultra dual a month ago ang since then the selfiecam had malfunctioned and the selfie mode icon on the cam window doesn't appear anymore. Hoping someone can help me fix it. Thanks!
5 REPLIES 5
Uliwooly
@1812
That's most likely a hardware issue, you could repair the phone with XC  but you might want to contact your Local support
Xperia Companion (XC)
Software Repair Guide
http://talk.sonymobile.com/thread/36355
YoGem
Leader
As Uliwooly rightly stated it's 90% hardware. The only reason why the camera app is not showing the selfie cam button is because the device it's not recognizing it. A drop cannot damage software so I am inclined to think it's for sure not a software issue but an hardware one.
However, doing a software repair may help you to avoid headaches and be sure that is an hardware issue rather than software BUT you may 1st try something different.
Open the dialer on your phone and type *#*#7378423#*#* to access the service menu, go then to Service Tests and try the front camera from there. If it won't work then you are sure it's not a software issue because the service app don't use system apps but native code embedded that is able to control and diagnose hardware.
Let us know! Slightly_smiling_Face
Didrik
Enthusiast
Hi @1812,
I'm sorry to hear that.
If this happened directly after you dropped the device it is most likely hardware related. As previously suggested in this thread, try performing a software repair using Xperia Companion to rule out this being related to software. If that doesn't help I recommend contacting your Local support to have your device sent to and examined by an authorized service center.
Juan_DVE
I did what you said before. I only could turn on the front flash but as you said, it showed me that frontal camera is not recognized.
YoGem
Leader
I suspect that the camera chip detached from its socket in the motherboard after the fall or, in case the cmos is soldered, that the chip got damaged or its not soldered solidly enough to work/being recognized. I am afraid you'll have to pay a visit or a call to the local support to have it inspected and repaired. Slightly_frowning_Face
