when i download data files for any game i put it in the (obb) in the internal storage and install the apk the game works propably but when i put the data files in the (obb) in the SDcard the game start for 5 second and exist to home screen
I do not think you can move games data to the SD card.
i move it but it doesnot work
Are you using a file explorer to move?Because apps or their data cannot be moved to SD.
yes i used file explorer
Yes,the game might only recognise initial install location.
