Google Maps / GPS doesn't reconnect
Darkfalz
When I lose GPS in Google Maps navigation, it never-ever reestablishes. Can confirm this on both my and my wife's phone. The quickest way to re-establish is to go into the quick settings widget and disable/enable GPS. But you shouldn't have to do this!
2 REPLIES 2
Jake-SonyXperia
Champion
Hi Darkfalz,
Welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
Has this only started to happen or has this been happening for a period of time, this sounds although it could be related to software in this instance. Can you please clarify if you have performed any troubleshooting?
I apologize for the inconvenience this may cause.
Darkfalz
This occurs on both my phones (C1905) and both before and after latest system update.
After losing GPS signal, it sits on trying to find GPS signal forever unless I either quit out and go back into Google Maps, or disable/enable the GPS hardware.
