GPS problem
Doran
GPS problem
GPS see the satellites and fix is very fast. But the signal is very weak and accuracy is 100-300 feet. This is unusable for navigation.
Tags (1)
5 REPLIES 5
Uliwooly
Settings > location > high accuracy
Doran
Yes, I already use this option.
Uliwooly
You might want to contact your local Xperia Care
http://support.sonymobile.com/global-en/contactUs/
Doran
OK thanks.
Uliwooly
Anytime
