gps problem
akkad
gps problem
i have a problem with my gps the arrow is pointing to a other direction not the direction i'm pointing my phone to in google mape i dont know if its a hardware issue or what
Tags (1)
4 REPLIES 4
profile.country.RO.title
_alexdon_
Have you tried to set location on high accuracy?
alexdon
Thommo
Try another app like the free version of Copilot - I'm not a fan of Google maps and have had issues with it in the past but never with Copilot but I use the paid for version
akkad
I had a cover for the mobile whith a magnetised part it was affecting the gps i remove it and the problem still their...i hit the mobile twice then the problem is gone..never thought hitting the mobile would fix it:-D
CC4Smiles
Sounds to me like you are getting confused with your GPS and your Compass...
GPS provides position but not heading, this function is provided with the Magnetometer / Compass...
Goto you dialer and enter *#*#7378423#*#*
Select Service Tests
Select Compass and follow the onscreen instructions.
This will calibrate your compass and give you a more accurate heading in your apps...
