I would like to save my phone before bringing it for repair .. it has fallen into water, and when I picked it, it was still on, but immediately after it is turned off. now doesn't turn on and will not charge. how can I do? (sorry for my elementary english)
As the phone has embedded battery,I do not think there is much you can do to save it.Try putting it in a bowl of rice(for a couple of days).After that,make sure that it is not wet at all.Connect to wall charger,charge for 2 hours,attempt a repair via sony update service.If this does not help,you need to take it into service.
I WIN XDI told you to keep it in a bowl of rice for about 1-2 days,I have seen it helps in some cases.But do try with the hair dryer.
