how do i enter myb puk code on xperia e3 i hve code but cant put it in?
Are you being asked to enter a PUK code?
Can you give us a brief run down of the build up to being asked if that is the case to enter the PUK code
yes i was putting a sim lock on and it locked i hve the puk code its saying 2 put in but whn i do there is no ok button r anything 2 put it in any advice wud b much apreceaited
As far as I'm aware you enter this code on the dial pad then tap the bottom key that looks like an arrow then if correct you will be asked to enter a new pin code
