Hello , how i can clear data for diagnostic on settings->App ? i cant find the application ...what name is use ?
Hi @Leap_ahead,
As far as I know Diagnostics isn't available as a separate app that you can clear data for.
May I ask why you are looking to clear data for Diagnostics?
just to clear data to not get storage...
I can forward this as user feedback but Diagnostics should not store any significant amount of data so I wouldn't worry about that in this app's case.
