Hello,
I have an Xperia Tablet Z with WiFi and 3G access(4.3 installed). As I'm most of the time connected to WiFi, I'm looking for an options to completely disable the 2G/3G network access (voice and data), similar to flight modus toggle (. I could not find any option in settings nor respective App. Simply disable data is not sufficient for me.
Any good proposals, options
Many thanks
Dieter
Airplane mode should do it,just reactivate wifi after you enable airplane mode.
