How can i remove apps from Vodafone?
Settings > apps > all > look for the apps disable
If you want to permanently uninstall them then you have 2 options
1. root your phone and remove them
or
2. flash your phone with the global generic firmware
You should be able to disable them.You can uninstall only by rooting.
