How do I turn of the autostart of slideshow when setting the phone in the docking..?
Check under settings > display > daydream.
If daydream is turned off. Open the application SmartConnect and turn off the event trigger by the docking station.
Hi. Seems like the annoying slideshow is running while daydream was off. Now I have turned it on, but only with colors while charging the battery. But i would like to turn it off completely. How do I do that?
@guntho - Have you tried disabling the function in Smart Connect as recommended above? if you are still having trouble with that then please try clearing the application: Main Menu > Settings > Apps > All > Smart Connect > Clear Data.
Don't forget to mark posts that answers the topic as Accepted Solution.
If you find any post helpful, press Kudos.
What are your thoughts about this forum? Let us know by doing this short survey.
