Insufficient Storage
Niiro
Since the last update I've been having an issue with Google play telling me that I have insufficient Storage when I'm trying to download an app, yet when I check I have something like 400Mb internal and over 20Gb external available, the apps are nothing more than 40Mb and I can't clear anymore storage without having to factory reset. Has anyone had a similar situation and found a resolution?
Thanks
8 REPLIES 8
profile.country.RO.title
_alexdon_
You can move some of your apps to internal.Settings-apps-all-downloaded,there are all your apps downloaded and installed.
alexdon
Niiro
I have already moved all possible "transferable" data to the internal storage
_alexdon_
But how much free space do you have in downloaded (phone memory)?
alexdon
Niiro
as specified in the original post, over 400mb of 2gb.
_alexdon_
Could you perform a software repair?
alexdon
Niiro
Does that involve connecting to a PC, last time I connected it I kept getting errors with the companion software
_alexdon_
Yes,that is what it involves.If not,you can stop by a sony service :
http://www.sonymobile.com/global-en/support/contact-us/
alexdon
Niiro
Ok, I'll give it another try.
