Internet connection problem
Introubled
I can no longer connect to any wireless internet using my Xperia tablet. Everytime i tried, it will just write "Saved, secured with WPA..." And i can't browse on the internet? what should i do?
2 REPLIES 2
Jake-SonyXperia
Champion
Hi Introubled,
Welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
Just to clarify, you have tried powering down the device and restarting and then trying to connect? Can you also advise if this is multiple connections or just the one at your home location?
BoeingBoy
Seems to be a common problem on my phone (SP and Z3C) and tablet.
I usually just turn off the WiFi facility off for a few seconds and then turn it back on. The local network will then be found and it usually reconnects OK.
Failing that try a full shut down and restart.
