I noticed some bubbles underneath my screen protector yesterday so I removed it and threw it away. Since doing this I've noticed that my keyboard is really difficult to use. The swype function doesn't work well at all and some of the other keys can't be pressed, the C key for instance just selects V.
I've messed around with the keyboard settings and have restarted everything but nothing seems to work.
Removing a screen protector wouldn't have damaged your device so I'd clean my screen in case you have residue causing a refraction
Hi, it doesn't feel as though the device is damaged. I was wondering whether the phone has gotten used to me swyping a certain way on the keyboard and now that the protector has been removed it's changed.
I'd clean the screen and test and if that fails then try a system repair and if it still happens then you'd need to have your device checked by a service centre or return it to the place of purchase
