I have updated the phone with SUS to version 4.3 and reinstalled most of my Apps. Everything was working fine up to the situation that I connected the corporate mail by Exchange ActiveSync. This forced the security settings to use a PIN with 6 digits. After this I found that the widgets on the lockscreen couldn't changed now. Before that I could swipe right for additional widgets and left to the camera. But now the widget is fixed (only the time widget is visible).
Aditionally I use the SmartConnect to start the walkman when I fit inn the ear phones. After this the widget showing the date/time was gone but the walkman widget is only visible a small part at the rigth side. Also the touchscreen on the lockscreen needs half a second to register the given input (vibrate and visible digit).
Any idea or other people with the same problem?
I had the same problem, after reboot my phone in the next few day, it back to normal. Don't know if the same trick will work again.
