Loosing mobile data connection after marshmallow update
nikwolf
Hello,
after upgrading my Z3c to Android 6 I'm frequently loosing my mobile data connection when I'm leaving home (and switching from WiFi to mobile internet). Before upgrading my phone it has worked without any problem. I need to restart the phone to get back mobile internet.
I tried software repair, but this doesn't solve the problem.
My wife has the same phone and also experienced the same problem.
What can I do to solve it?
Regards
Frank
8 REPLIES 8
Uliwooly
@nikwolf
once you leave the wifi are, wait 30 seconds assuming that you are far enough that the phone can't detect the WiFi/router; you can also test it in >>> safe mode
nikwolf
will do.
Kilo-7
Lose the Kurt COBAINE quote please. Perloined from me!!
Uliwooly
@Kilo-7
Spell check
nikwolf
Problem also appears in safe mode.
Haven't observed it with Android < 6 either.
Cheers Frank
vinc3
same probleme here, can't fix it without a restart
the_Driver02
I have the same problem. Only a restart fix the mobile data connection.
nikwolf
By me, the Problem does not occures if LTE is switched-off (2G/3G only).
Have you tried this also?
