You could try Recuva via your Pc connecting your SD card direct to it and not via your phone - However I find it safer to transfer images etc via a Pc using the copy and paste feature then once your are sure everything has transferred then and only then delete files from internal storage
This lost photos and lost video problem i am experienceing with my newly acquired z ultra. and after lolli pop update the phone is in continous boot loop.
please help.
@moazzamalikhan Try performing a system repair using PC Companion as this will often fix issues - This will factory reset your phone and erase all data
Switch off your phone and unplug from Pc (Hold volume up and power for around 10 seconds)
Start PC Companion and select Support zone then Update my phone/tablet then in Blue Repair my phone/tablet and follow the on screen instructions - When prompted connect your phone still switched off holding volume down or back button - This should start the repair or reformat process
If you are using Windows 8/8.1 or a 64bit operating system then adjust the settings for PC Companion and run in compatibility mode and chose Windows 7 or XP
Thank you Thommo. i just did exactly what you guided. i will let you know what i found. good or bad
Dear friends and SONY
it took me whole week end, two days, trying to solve the bootloop problem. but i couldnt, could you please please please tell me how to downgrade back from lollipop to kitkat 4.4.4 atleast i start using the phone as per daily use. by this bootloop i cant do anything, and its very irritating.
the problem comes up the moment i connect the usb cable, the phone starts back this habit, just after solving or resetting the phone from sony pc companion.
please help. thank you.
