loudspeaker talk problem
lukas86
hello,
receantly I've bought z3 compact...and everytime I'm trying to talk on loudspeaker everybody is telling me to turn it off because it is impossible to talk further when they are hearing everything they are saying back.
Any one have resolution to this problem ? because for longer talks I cannot imagine holding my hand near head all the time and I was always using loudspeaker talk option in phones.
Please help !
8 REPLIES 8
Jake-SonyXperia
Champion
Hi lukas86,
Welcome to the community,
From what I gather, it seems you are having issues with echoes on the call. The first thing I will ask is if you have a cover on your device and if you do can you please remove it and then test it.
lukas86
Well I've just removed casemate etui and peoples were still hearing such echoes that talk cannot go any further. They even suggested that no differance at all with or without etui cover.
next suggestion please ?
Jake-SonyXperia
Champion
That is very strange, generally this would be related to the case as the audio is bouncing and hitting the mic which causes an echo.
On the off chance that this may be software orientated, you could attempt a Safemode boot and test to clarify.
Safemode instructions
muser
It's the same for me! With the latest update of my z3 compact. 23.5.A.1.291
During speakerphone (vivavoce) the called party hears interferences !
lukas86
I'm sorry to deliver bad news to You but it's again not that.
I have acces to two experia z3 compact and both are with the same problem. My is from distribution from poland and I've actualized to android 6.0.1 and the other is from distribution from above UE country and it works on android 5.0 something and my girlfriend is using it.
Please sony make something or say what option to hit/switch....it is not normal to not be able to use loudspeaker option for phonetalks....it's realy a shame for SONY that 2 phones from different distribution routes have the same problem and are not able to use so basic function.
sincerely plese say how to repair that.
lukas86
sony please give me solution to this problem. Maybe everybody with z3 compact are unable to use loudspeaker talks ?
Jake-SonyXperia
Champion
Hi lukas86,
There is no known issue regarding this, have you attempted a software repair on the device?
Software repair instructions
muser
I did software repair, but does not solve the problem Slightly_frowning_Face
