low alarm volume
akkad
low alarm volume
I have a problem with my xperia z2 its about the sound of my alarm volum its too low when it starts...i tried every thing... The alarm setting is set as loudest level... When i choose the sound of my alarm its normal and very loud but when i use the alarm its lower...i even tried an other alarm app from the market and its the same problem
Tags (1)
13 REPLIES 13
profile.country.RO.title
_alexdon_
Settings-apps-all-sound enhancements,force stop and clear data.Restart.
alexdon
akkad
Didnt find "sound enhancements "
_alexdon_
Even if you scroll to all? It should be there.
alexdon
akkad
I have android 4.4.4... And i'm sure there is no "sound enhancements " 😞
_alexdon_
Strange,it can be found in my Z1 and I am sure in most of Xperias.In this case,boot in safe mode and check if the same occurs:
http://talk.sonymobile.com/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008
alexdon
akkad
This dosent work for my kitkat also i cant boot it in safe mood
_alexdon_
Have you pressed the power button and after that tapped longer on turn off? you should get a message to restart in safe mode.
alexdon
akkad
It doesnt work with kitkate i think
_alexdon_
Of course it works.
alexdon
