Low battery sound
JalosMama
Low battery sound
I don't want to hear "warningsound" when battery is low. How to turn it Off? Cant't find Slightly_frowning_Face
3 REPLIES 3
Uliwooly
@JalosMama
I don't think it can be done.
profile.country.RO.title
_alexdon_
@JalosMama Is stamina enabled? You can try to set your device on vibration only.
alexdon
YoGem
Leader
There is a way, no.. There are Multiple ways but all requires "root" - I do not recommend you to root your device unless you are a pro user, knows what to do and can live without having the manufacturer warranty.
If then the urge to disable that sound is great, root your device. Use a root file browser, search for the notification files, find the one that read lowbattery.ogg or similar and replace it with a muted ogg file (you can find many of them online)... Reboot your device and no more sound!!!
However, seriously... Don't do that.
