LT26i
harleybarls
LT26i
Any help would be great, my phone wont charge it just shows red light when USB connected so it wont  update.  I've tried all the usual stuff they tell you to do but nothing much happening. the screen libhts up for a while when on charge but goes off after 5 seconds when holding down buttons. Please anyone help me
3 REPLIES 3
profile.country.RO.title
_alexdon_
You may need to perform a software repair using PC companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 60% battery.
Make sure the device is not connected to computer or laptop and turned off (sometimes you have to press power button and volume up until the device vibrates 3 times or on some devices you have to press the small button near the SIM tray or on the back of the device).
Open PC companion->support zone->phone/tablet software update->repair my phone/tablet blue highlighted.Follow the steps given,do not connect your phone until prompted to press volume down while plugging USB cable. If PC companion does not start the repair process, you might need to run it in compatibility mode with Windows 7 (in some cases XP).
alexdon
harleybarls
Cheers buddy but tried all that, it's not turning on it's been on charge all night. i know all data will be lost but just want it back on
_alexdon_
You do not need to turn it on,just make sure to follow the steps given by PCC.
alexdon
