Malfunction sd card
as2
Malfunction sd card
I got the T2 Ultra just some weeks ago and the sd card keeps getting unnexpectedly removed any quick movement I make with the phone. Any ideas?
1 REPLY 1
Thommo
Check the SD card is inserted correctly and check that it is free from dirt and defects - If that fails then check with another SD card and if the same happens then you need to either return your device to the place of purchase or contact Xperia care http://www.sonymobile.com/global-en/support/contact-us/
