Marshmallow update doesn't automatically detect fingerprint
Akshay1690
Before marshmallow the fingerprint scanner would work even without pressing the power button. However, after the update we are made to press the button. Why is it so? Is this issue faced by all or its just me! I fail to understand why would I need to press the button again an again to unlock where it should automatically detect.
Tags (1)
3 REPLIES 3
profile.country.RO.title
_alexdon_
@Akshay1690 You only need to press the button in order to light up the screen if double tap to wake is not enabled. Could you check if the same occurs in safe mode?
alexdon
Christofer
Champion
Hi @Akshay1690,
Like alexdon said you should not have to press the power key once the phone is awake in order for it to scan your fingerprint. safe mode is a good idea but if that does not help you should perform a software repair using Xperia Companion.
Islamxy
1.To save power button you can do the following:
Go to settings>display>and check double tab to wake.
2.To power off screen without using third party application:
Go to home screen and press long in empty area >choose settings>check double tap to screen off.
