Message tone problem please help :)
Not applicable
i have a mp3 file a a text msg  tone when i recive a msg the tone keeps going even when ive opened the  msg any one ideas how to stop it without changeing or shorting the mp3  file
Regards
d900m
3 REPLIES 3
higwayman
use handcent SMS
Not applicable
i found that using the notification window to open the message stops the tone immediately. using mini pro btw.
Not applicable
Thanks ive tried hand sms and it still the same ,and with the notication window on the mini is just the small text icon in one of the corner is that what you mean regards d900m
