Move data from the internal memory to the SD-card
abdurrahman
I want to ask, xperia t3 I can not move the data from the internal memory to sd card, please help?
Tags (1)
5 REPLIES 5
profile.country.RO.title
_alexdon_
That's normal,you can entirely move only media files.
alexdon
abdurrahman
Ok thank's
_alexdon_
I am sorry to tell you about moving apps to SD but the option isn't exactly what everyone expects. Read more here:
/t5/Software-Updates/Apps-moved-to-SD-card-still-reserve-space-in-internal-storage/m-p/956195#U95619...
alexdon
Mtexus
Hey names mtex, new to Android my first one being the Sony Xperia t3 which I hav had for 9months now and I love it.. Go Sony lol...anyway I bought a 32gb memory card but still hav problems were my apps are taking most of my internal memory space 95%of it 😔... I hav tried sending the apps to the memory card but when I do so they don't work so I ultimately hav to put them back into phone memory which still remains full.. Please help, what can I do to free up internal memory
Emir1
Hero
Hi @Mtexus,
How do you move the apps to the SD card? Are you using a third party app to force them on to the SD card, or are you using the native way found under Settings > Apps? If you use a third party app to force app to the SD card which are not meant to be installed there, then you may experience that they do not work properly.
