It would be great if you could rotate the screen 180°. I'll try to explain: the headset is usually worn to the left. So, when you use it, you take it with your left hand, and the cord is also expected to be at the left side. But instead of it, it goes to the right, partly overlapping over display and headset itself. Not much convinient. Hope you understood, what I mean:)
I suppose, this can be easily resolved by simple firmware update.
im totaly agree with you, i also realized same thing and it should be solved by one firmware update.
I agree too! Headset connector at the "bottom" of the phone would be better. Like the iPod Touch. Good idea!
What phone are you talking about? We're discussing MW600 headset here.
Sorry, my mistake!
You mean the display of the wireless headset?
OK, I wear my headset on the right side, so I don't experience that problem.
(While reading the original post I forget the the post's title, and suddenly thought you were talking about a cable headset.... Sorry.)
