Need help with Mms settings please!
Not applicable
I was wondering is there anyway i could download the mms settings for my Aino through my laptop or have them manually put in my phone,, My phone is unlocked and i use the phone with a intenational sim car which works fine,, I can get on the web using the wi fi but when i go to download the mms settings it says must connect with internet,, Someone please help i need to be able to send pics otherwise this phone is worthless, Thanks Slightly_smiling_Face
1 REPLY 1
Not applicable
"must connect with internet" means your internet account is either not set up or you have not connected to a wifi network have not connected to the internet yet.
1) set up your internet options
or
2)log into your secure wifi network, then have your netword connect to internet using your laptop as a local hub.
