After the latest update for the Z5 Dual, I find that it's not as good as the previous STAMINA mode in the android 5.1 update. It could be improved. So hopefully that you could take some consideration on improving it. Like the STAMINA icon is nicer that putting it as a notification. It's quite annoying as I can't swipe it away.
After upgrading to 32.2.a.0.253, the heating looks like it have solved almost. It hardly heats up.
Also, if the stamina mode is on, it keeps on appearing in notification drawer, the + sign beside the battery meter earlier worked best for me.
Can anybody help me out?
need option to close anything you want and not just reduce DATA, also option disable google play (like greenify app)
(google play its gray on stamina setting)
PS
for the one above me
i dont think u can rid of
STAMINA icon's while is on like it was before only if you rooted (also not 100% sure)
