No 5Ghz Wireless
awmackay
No 5Ghz Wireless
Hi all,
Not sure when it first occurred (before lollipop, I hoped it would fix it!), but I cannot see or connect to any 5GHz wireless networks on my Xperia Z3 Compact.  Using a third party app I can't see a single 5Ghz network regardless of what channel I change it to on my router.
The phone is up-to-date, has a valid sim card and works fine for all other services.
The strangest thing is that the network I'm trying to connect to is not a problem for my other (identical) Z3 Compact...
Any ideas on what to do?  I'm not keen on having to do another factory reset/restore...
4 REPLIES 4
Uliwooly
Do you experience the same with other routers?
awmackay
I've tried on other routers too (with both phones too)... Same result!
awmackay
Stil no progress with this.
I have two Z3 Compacts, one can see the 5Ghz and one can't...
Does anyone from Sony every help with this forum?!
Uliwooly
@awmackay
this is a user based forum, if you want support from Sony, you have to contact them directly
http://support.sonymobile.com/global-en/contactUs/
