Not enough space on SD
Esy
hi
i have updated my Z2 to android 6.0.1 two weeks ago.
but i found out some problems happened to my device!
however some prople may have pionted to it but it is very important and necessery.
in android 5.1.1 ٫ we could transfer applications to SD card by using "transfer data to Sd card" option or we could move them manually.
unfortunately not only "transfer apps" is missed in submenue of "transger data to SD card" ٫ but also i can't transfer them manually and whenever i try to do that٫ my device send "no enough space" (although my SD card has 10 Gb free space)
in addition٫ the "backup & reset" icon is missed in apps pages. its shortcut was very useful for me.
regards
2 REPLIES 2
Uliwooly
@Esy
Are you able to move files from the internal storage to the SD card using the File Commander?
profile.country.RO.title
_alexdon_
