My phone has been playing up since last night and It takes a good half an hour to recieve a text, does anyone know wether this is a problem with the phone itself or the network?
I can sent texts out and they were etting recieved by other people
Thanks in advance
I'd check with the network 1st as it maybe an issue from their side in regards to forwarding messages to their network but sending out it will be forwarded onto other networks for distribution
Is there a way to check? Ive tried googling to see if my network is having a problem however there doesnt seem to be anything said?
Normally you'd ring and an automated message maybe left and if not then they may not be aware of it
You could also just contact your carrier/network
