Notification bar clock
ruixiangz
Ever since the upgrade to Lollipop on my Z1 compact (which is bad by the way), the clock / time has been missing from the notification bar. This is irritating because I'll always have to go back to the home screen to look at the clock widgets to see the time. How can I get it back on?
1 REPLY 1
Hampus
Champion
Sorry to hear that you are not satisfied with the Lollipop update.
Could you check via Settings > Personalisation > Status bar icons > Time, so this one is marked? If it's not, you will not see the time in the status bar.
