Phone not connectig to computer
YQ
My phone sais its internal memory is connected to the pc, it also charges. but my PC companion does not detect it and therefore i cannot acces my files whilst on my PC and nowhere i can find a solution to this. it connected once but doesn't do it again.
14 REPLIES 14
Uliwooly
settings > xperia connectivity > usb connectivity > usb connection mode > mtp
YQ
The mode was already on MTP
profile.country.RO.title
_alexdon_
What windows are you using?
alexdon
YQ
i am using windows 7
Sanj
you may follow the following :
  1. Disconnect the phone from computer.
  2. uninstall the PCC
  3. reboot the system
  4. Install the PCC.
  5. reboot the system.
  6. once rebooted run the PCC
  7. now connect the phone to computer
let me know how it goes.
Sanj
YQ
will it be smarter to install it by using the phone or by getting it from the website?
_alexdon_
Download from the website.
alexdon
YQ
unfortunately this also doesn't work...
_alexdon_
If you select mtp mode in connectivity,how is it?
alexdon
