phone turning off
dinnu
phone turning off
oh cm'on i was expecting a better upgrade from sony this time, and my hopes are just ruined .  phone gets stuck and turns off ( it happens like 5-10 times daily ) .
music app on the lock screen is still flickering.
phone became soo slow , some times the touch is not working too and then it turns off .
The worst thing , i dont know why my phone shuts off even there is enough battery power and even when the i amnt using any apps .
hoping for a better update  next time 😕
4 REPLIES 4
Nabeel
Master
Let me know if your experience improves after performing a repair using SUS.
Backup everything as it will erase all data on phone (sms, contacts,apps)
Update/Repair your phone via SUS
SUS ( Sony Update Service) ... download and install it on pc and follow the on-screen instructions
http://www.sonymobile.com/global-en/tools/update-service/
mani90
To
The Moderators
Do u know any other solution which actually works.?? Or u have learnt only one.!! Clean installation.. For your kind information, this solution seldom works..my phone still restarts randomly even after repairing it wid SUS
profile.country.RO.title
_alexdon_
Do you have task killers or antivirus?
alexdon
Nabeel
Master
@mani90 wrote:
To
The Moderators
It's the most basic thing to start with and this solution does work for 90% of the users. It's always seen that whenever there is a shift from one android version to other, the meta data from previous android version kind of clashes and creates lag. So it's always adviced to perform a clean repair.
Your problem might be different and hence you need another solution. So did you create any thread or you just like to pop in other threads that has different problem compared to yours and post this >Do u know any other solution which actually works.?? Or u have learnt only one.!!
I'd like to try to help you with your thread. Slightly_smiling_Face Or maybe you can post your problem with details next to my reply.
