Playlists on X10
Not applicable
Playlists on X10
What's the easiest and best way to create playlists that is recognized by mediascape??
4 REPLIES 4
sushidushi
Contributor
I have made playlists using Windows Media Player and just copied them over using Media Go.  Works perfectly.  I have heard others saying they've used WinAmp without problems, too.
Not applicable
Thanks for the idea.
But it would be great if we can create playlists as we have in walkman series Slightly_smiling_Face
sushidushi
Contributor
I wholeheartedly agree!  I loved my old SE (?)580i in that regard.  It never occurred to me that it would not be possible on the X10.
If you search in the Android market, I think there might be at least one music player application that enables you to make your own playlists.  The Meridian application allows you to make your own play queues, but that's not quite the same thing.
Not applicable
I am not able to succeed with windows media player playlists. need to try again.
