Please help, Xperia SP Home
Luca1
On Xperia SP 4.3 .205 what is the version of the Xperia home?
6 REPLIES 6
Thommo
Open Settings then Apps and swipe to All then scroll down and look for and open Xperia home and you'll see the version number
Luca1
I can not do it, I no longer use the original home
Thommo
So you have removed Xperia home ie:Uninstalled it, even if you have a custom rom or launcher you should still be able to enter the above guide to locate Xperia home in the apps list
Luca1
The fact is that I installed the Z3 Home, then I clicked uninstall updates, but I think it has also deleted the updates of the official 4.3
So I want to know if I have the stock version or not, now says that I have the 6.1.2.A.0.1, is the original of 4.3 .205?
Amey
It is 6.1.2.A.0.1
Luca1
Thanks
