Pokemon Go
ply17410
Pokemon Go
How does the XA perform running the game?
Thanks,
Bob H
3 REPLIES 3
Uliwooly
@ply17410
I have the Xperia X and it's great, if you are using a car charger or a power bank the battery won't drain at all, but will be interesting to know how it perform with the XA
YoGem
Leader
It performs very well in my C5 that is a little bit underpowered compared to the XA, however the lack of gyroscope may provoke some shaking images at times. Not that bad though.
AikoSc
Playing it on ultra drains the battery fast. I understand location is on and data plus a 6 inch display in used but the battery drains to fast. Aside from that, it's perfect on Ultra.
